OrbiPhilip
Jul 13, 2017Luminary
Brother MFC-9430CDW wifi failure
Since the 1.11.0.20 firmware (currently 1.12.0.8) my printer will (if power cycled) connect, stay connected for a few minutes, then fail. This printer worked fine on my previous router (WRT54G) and ...
OrbiPhilip
PapaMike wrote:Check the printer for updated firmware/software. If up to date, run the printer setup again and that most often repairs any disconnection.
I think you missed the point. It was working fine pre-1.11.0.20. And it works fine on other APs. But on Orbi w version 1.11.0.20+, it no longer works.
PapaMike
Jul 14, 2017Star
Did you try my suggestions?
- OrbiPhilipJul 14, 2017Luminary
Yes, as as of this writing it appears to be working better. Drops have been elilminated, but ping times are still ridiculous (avg 24ms, peak 1000ms).
That said, the issue remains that v1.11.1.20 & v1.12.0.8 broke connectivity with a relatively new device.
