computersteve
Apr 26, 2018Apprentice
Brother MFC Printer Disappears From Network
I have a Brother MFC-795CW & I keep having a problem with the printer just disappering from my network. I have to do a power cycle for the printer to be re-recognized by my Mac. I have tried resettin...
Apr 26, 2018Guru - Experienced User
Have you set up a reserved IP address ON the router for our printer or set a static IP address of 192.168.1.79 ON the printer?
I would uninstall and re-install the printer driver on the Mac. Make sure it's up to date.
Contact the Mfr of the printer for additional help and information on this as well.
computersteve
No I havent setup a reserved IP but why should I do that? I never had to do that before..
- FURRYe38Apr 26, 2018Guru - Experienced User
Helps ensure the printer gets one same IP address each time it's turned on and doesn't change.
Hope it works better for you.
- computersteveApr 30, 2018Apprentice
So for me, setting a static IP seemed to fix the problem. Thanks for the suggestion =)
- FURRYe38May 01, 2018Guru - Experienced User
Glad it's working better now. Enjoy.
:smileywink:
