paulcwr
Oct 30, 2018Tutor
BRS WAN LAN conflict
for some reason, even though my Orbi with 2 satelites had always worked fine, since about mid october, whenever on an apple device (never tried on a PC since i don't own one), whenever I go to a site...
- Oct 30, 2018
What FW is currently loaded?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
ekhalil
Oct 30, 2018Master
paulcwr wrote:
..... My setup is that I have a dsl modem+router in which I plug in the orbi router, and this one acts as a wifi hub and also provides ip connetivity to two satellites. ....
Please make sure that your "dsl modem+router" is set to bridged mode and is not acting as a router, if you have the Orbi set to "Router Mode"
