paulcwr
Oct 30, 2018Tutor
BRS WAN LAN conflict
for some reason, even though my Orbi with 2 satelites had always worked fine, since about mid october, whenever on an apple device (never tried on a PC since i don't own one), whenever I go to a site...
- Oct 30, 2018
What FW is currently loaded?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Oct 30, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
paulcwr
Oct 30, 2018Tutor
This worked. I disabled the daisy chain functionality and now I can visit all web sites, even those using HTTPS without having this BRS WAN LAN contflict and the mysterious login page.. thanks for your help.
paul
- ekhalilOct 30, 2018Master
I think that this worked only temporarly since disabling Daisy Chain causes a system restart. I expect that you can see the issue again when a new IP address conflict will occur next time you make another system restart (on next software update for example :) )
I suggest that you solve the root cause of the issue instead.
- paulcwrOct 30, 2018Tutor
thanks for helping. I am sorry to ask but I am not too competent on dsl modem programmeing so how do I solve the root cause issue? can you please point me to a step by step guide? thank you
What is the brand and model of your DSL modem+Router? Do you have a manual for it so we can check how to change the configuration to bridged mode?
- FURRYe38Oct 30, 2018Guru - Experienced User
Glad the change worked.
If everything is working, you might run it for now and leave the system alone. Maybe no need to bridge the modem...
paul
