krohleder
Jun 28, 2020Aspirant
BRS_wanlan_conflict.html issue
I have a BRS_wanlan_conflict.html issue on some sites including the Orbi web based admin page. So the following is recommended but does not work: --- Your ISP modem will already have a built in rou...
Jun 28, 2020Guru - Experienced User
What is the model# of the modem? Try a different modem by chance if DMZ is causing the modem and Orbi to crash.
I would configure the Orbi for AP mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can review and try this if you have the ability:
krohleder wrote:I have a BRS_wanlan_conflict.html issue on some sites including the Orbi web based admin page. So the following is recommended but does not work:
Your ISP modem will already have a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.---
Unfortunately:
1. AT&T no longer supports transparent bridge.
2. Turned off the all wifi radios on modem. Setting DMZ/ExpoosedHost or IP Pass-Through will cause both systems to crash and you will need to do a hard reset. I confirmed with AT&T they do not really support this anymore.
3. You cannot access the routers web based page since it will give you the very error you are trying to fix in the first place.
admin and password do not work when the orbilogin.com redirects to http://orbilogin.com/BRS_wanlan_conflict.html and brings up a user name password prompt. http://192.168.1.1 or http://10.0.0.1 gives the same result.
Is there an actual solution for users with AT&T?
- krohlederJun 28, 2020Aspirant
I am using the Orbi RBR50 with the AT&T modem which I must use with the service. I cannot use another modem.
- FURRYe38Jun 28, 2020Guru - Experienced User
Try AP mode then. Should work. A reset on the RBR maybe needed. I would manually configure the RBR with it disconnected from the modem first. Set a new IP address, 192.168.1.50 on the RBR for AP mode so you will always access the RBRs web page at this address. Set your modems default IP address range to 192.168.1.100 to .200. Save all settings then reboot the RBR and connect the WAN port to the back of the modem.
I cannot access the web interface to set it to AP mode.
