rsutter9950's avatar
rsutter9950
Follower
Feb 13, 2020
BRS_wanlan_conflict.html with netgear modem and orbii
I have just experienced an issue with connectivity. I had to 'reset' my cable modem
Netgear CM1000
with an Obri router RBR50
where I receive this error when I attempt to connect to a site:
I have a cable connected from the modem to the Orbi and I do have a good speed connection until I try to connect to sites that require a login, something that is definitely wrong.
I will continue to search the forum and community
1 Reply
  • FURRYe38's avatar
    Try a different browser. IE11, FF or Opera.
    Be sure to clear out ALL browser caches.
    Has a factory reset and setup from scratch been performed since last FW update? Power OFF the modem for 30 seconds then back ON while RBR is being reset.
    Please do not post serial numbers to your equipment. Can present a security concern.
