greenkaczka
Mar 30, 2020Follower
BRS_wanlan_conflict.html with orbi - and connecting to webpages with often 404 (page exists)
ATT modem (uverse) Orbi. connect the orbi to ATT directly per instruction. When my Orbi system is used I often get a pop-up message which asks for login information to websites, or message that s...
Mikey94025
Jun 12, 2020Hero
greenkaczka wrote:ATT modem (uverse)
Orbi.
When my Orbi system is used I often get a pop-up message which asks for login information to websites, or message that says no such webpage exist
The web adress is followed by - BRS_wanlan_conflict.html
It prevents me from using certain webpages.
FOUND NO SOLUTION ON COMMUNITY.
This happens when your ATT modem is a router and your Orbi is also a router, causing the Double NAT issue FURRYe38 described. You just need to put your Orbi in Access Point (AP) mode, so it provides just your wireless network, and leave the router function to your ATT modem: https://forums.att.com/conversations/att-fiber-equipment/brs_wanlan_conflict/5e728051c17a064135f077a4
From FURRYe38's reply here are the instructions to configure your Orbi in AP mode:
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
