greenkaczka
Mar 30, 2020Follower
BRS_wanlan_conflict.html with orbi - and connecting to webpages with often 404 (page exists)
ATT modem (uverse) Orbi. connect the orbi to ATT directly per instruction. When my Orbi system is used I often get a pop-up message which asks for login information to websites, or message that s...
leuchtag
Jun 12, 2020Aspirant
FURRYe38 wrote:Your ISP modem will already have a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
greenkaczka wrote:ATT modem (uverse)
Orbi.
When my Orbi system is used I often get a pop-up message which asks for login information to websites, or message that says no such webpage exist
The web adress is followed by - BRS_wanlan_conflict.html
It prevents me from using certain webpages.
FOUND NO SOLUTION ON COMMUNITY.
Thank you!!!!!!!! Following the Orbi manual instructions on setting the Orbi router to AP mode SOLVED THE PROBLEM. The hardest part was remembering my password to gain admin access my Orbi router -- I had to reset the password with the serial number of my Orbi Router after several failed attempts.
Jun 13, 2020Guru - Experienced User
Be sure to write down important information for safe keeping and remembering. :smileywink:
Glad you got it working.
Please mark your thread as solved so other will know.
Enjoy. :smileywink:
