JulietteT
Apr 12, 2020Aspirant
BT Home Hub conflict
Please can anyone help? I have sucessfully-ish installed my Orbi plus 2 satelites. I am currently using a BT Home Hub and this is causing some issues - can't print, can't access some websites (er...
Apr 12, 2020Guru - Experienced User
disabling wifi doesn't disable the routing aspect of the home home. it leaves you in a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
2 easiest options are 1. put the home home in passthrough/modem only mode or 2. put the orbi in access point mode.
michaelkenward
Apr 13, 2020Guru - Experienced User
Easier said than done, if not impossible with the HomeHuib. BT goes out of its way to deny users that option .
That works fine for many Orbi users. I don't have a HomeHub. (I've got three of them, two still shrink wrapped.) But I still have an AP Orbi network.
- JulietteTApr 13, 2020Aspirant
Thank you for the help.
Yes, I think putting the homehub into modem/passthrough mode is impossible.
Do you have any advice on how to do your second suggestions? I am not a techie at all so just stumbling through this progress while my family moan and complain about the pages they cant access!!! (To be fair, my eldest cant get logged onto her Uni library which is not helping her Masters dissertation much!!)
I'm sure there must be a solution.....
Thanks
Juliette
- FURRYe38Apr 13, 2020Guru - Experienced User
SImplest solution would be to configure yoru Orbi for AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Keep your Home Hub router as your main router. Disable ALL wifi radios on this modem. Have you ISP help you with this.- michaelkenwardApr 13, 2020Guru - Experienced User
That's a good idea, but you may not even need to do that.
The Orbi will give itself a different SSID. My router's wifi coexists happily with the Orbi wifi.
The only issue could be if they choose to squat on the same channels and when the family complains about which wifi network to connect to.
