JulietteT
Apr 12, 2020Aspirant
BT Home Hub conflict
Please can anyone help? I have sucessfully-ish installed my Orbi plus 2 satelites. I am currently using a BT Home Hub and this is causing some issues - can't print, can't access some websites (er...
JulietteT
Apr 20, 2020Aspirant
thank you for the advice however I cant make this work for me, unfortunately.
The problem is logging into Orbilogin. If I am attached via my BT homehub understandably the log in doesnt work because I'm not connected to the Orbi but if I log in while connected to the Orbi then I get the Error 404 message - i.e. exactly the conflict I am trying to remove.
There must be a way. Any help gratefully received.
Apr 20, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend trying option #2 or 3.
Make sure the IP address on the main upstream router isn't in conflict with the RBR. Walking thru the setup wizard on the RBR should help with this.
JulietteT wrote:thank you for the advice however I cant make this work for me, unfortunately.
- michaelkenwardApr 20, 2020Guru - Experienced User
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.Not possible. See above.
BT's HomeHub is designed to frustrate users on that front.
- FURRYe38Apr 20, 2020Guru - Experienced User
Updated post.
Thank you.
