JulietteT
Apr 12, 2020Aspirant
BT Home Hub conflict
Please can anyone help? I have sucessfully-ish installed my Orbi plus 2 satelites. I am currently using a BT Home Hub and this is causing some issues - can't print, can't access some websites (er...
Apr 20, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend trying option #2 or 3.
Make sure the IP address on the main upstream router isn't in conflict with the RBR. Walking thru the setup wizard on the RBR should help with this.
JulietteT wrote:thank you for the advice however I cant make this work for me, unfortunately.
The problem is logging into Orbilogin. If I am attached via my BT homehub understandably the log in doesnt work because I'm not connected to the Orbi but if I log in while connected to the Orbi then I get the Error 404 message - i.e. exactly the conflict I am trying to remove.
There must be a way. Any help gratefully received.
michaelkenward
Couple of options,
Not possible. See above.
BT's HomeHub is designed to frustrate users on that front.
- FURRYe38Apr 20, 2020Guru - Experienced User
Updated post.
Thank you.
