JulietteT
Apr 12, 2020Aspirant
BT Home Hub conflict
Please can anyone help? I have sucessfully-ish installed my Orbi plus 2 satelites. I am currently using a BT Home Hub and this is causing some issues - can't print, can't access some websites (er...
michaelkenward
Apr 20, 2020Guru - Experienced User
FURRYe38 wrote:
Couple of options,
Not possible. See above.
BT's HomeHub is designed to frustrate users on that front.
Updated post.
Thank you.
