internetgirl
Jan 28, 2020Aspirant
Buffering Issue on Newly Installed Orbi RBR50
I just installed the RBR50 with the Orbi Voice Satallie. Everything seems to working great and I'm getting excellent speed on wifi. However, I am having buffering issues that were not there prior ...
- Jan 28, 2020
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Jan 28, 2020Guru - Experienced User
internetgirl
Jan 29, 2020Aspirant
Thank you for your suggestions. I deactivated Armor and it worked! The buffering on both the Spectrum and Netflix app stopped.
The RBR50 is running firmware version V2.5.1.8 and operating in Router mode.
- FURRYe38Jan 30, 2020Guru - Experienced User
Good to hear. Armor is a security program so this may cause streaming issues. Keep it activated if you need when your not streaming. Otherwise, disable it.
Enjoy. :smileywink:
