majuga's avatar
majuga
Bug: Attached Devices and Satellite info
I have one router and two satellites setup throughout the home. Everything works perfectly, but when I login to the router settings and look under Attached Devices, the two satellites show up, but the subcategories: IP Address, Connection Type, and Connect Orbi are all blank. Also, under Backhaul Status it says they are both disconnected.
    What FW is currently loaded?
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Set up IP address reservations ON the router for the satellites. Wired or wireless connected.
    What browser are you using? Try IE11, FF or Opera browsers...
    • majuga's avatar
      majuga
      Firmware: 2.1.4.16
      Manufacturer and model #: Pace Plc, 5268AC
      -There is about 30-40 feet in between each satelite and router
      -I'm using Auto-channel and use Chrome for a browser, I'll try what you recommended.
      • FURRYe38's avatar
        Guru
        Also Modem Combo Units:
        Couple of options,
        1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
        2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
