toblerpwn's avatar
toblerpwn
BUG: Cannot edit "Internet" VLAN settings (e.g. Priority, VLAN ID)
Router Firmware Version
V2.0.0.74
Steps to reproduce:
1) Sign in to orbilogin.com (or whatever method)
2) Click the "Advanced" tab
3) Expand the "Advanced Setup" section in the left list, then scroll down within the list until you see "VLAN/Bridge Settings". Click "VLAN/Bridge Settings".
4) Click "Enable VLAN/Bridge group" and then "By VLAN tag group".
5) Highlight the existing/default "Internet" VLAN tag group and click "EDIT"
6) Change the VLAN ID (e.g. to 201, as I need to do for CenturyLink Fiber internet).
7) Click "APPLY"
Expected results: VLAN tag group page is shown with the new settings specified above.
Actual results: VLAN tag group page is shown with old settings; any changes are not respected/retained/saved. Using the exact steps above, the entire VLAN settings are disabled / not enabled. If you already have VLAN settings enabled, then the "Internet" group will simply remain in VLAN ID 10 -either way, it is uneditable.
Looking for Netgear help here, as this seems to be a bug in their firmware or router settings. Also very interested if others can reproduce, or whether this is just my device.
