-geoff
Apr 05, 2020Follower
Bug: RBR20 incorrectly uses link-local router IPv6 address as address for IPv6 DNS server.
There is a bug in either the SLAAC/DHCPv6/DNS server configuration when IPv6 (in auto-config and DHCP modes (etc.) is enabled. After IPv6 Neighbor Discovery ICMPv6 and Router Solicitation it is appro...
Apr 05, 2020Guru - Experienced User
Please file a support ticket with NG and let them know.
https://www.netgear.com/support/#
Good Luck.
-geoff wrote:There is a bug in either the SLAAC/DHCPv6/DNS server configuration when IPv6 (in auto-config and DHCP modes (etc.) is enabled. After IPv6 Neighbor Discovery ICMPv6 and Router Solicitation it is appropriate that the link-local IPv6 address for the gateway be assigned the gateway's IPv6 link-local address, as it *is* literally the "next hop" on the IPv6 protocol. However, unlike IPv4, this does not serve the same purpose as the IPv5 LAN IP of the gateway—the fe:80:: addresses are restricted only to local network functions, and can explicitly not pass requests from clients out to a global IP.
However, instead of assigning the gateway's IPv6 external address when assigning DNS servers to clients, it assigns the link-local address instead. That is, if my link-local IPv4 and IPv6 router addresses are 192.168.1.1 and fe80::26a0:74ff:fe74:caf1
(which are correct), presently, these same addresses are being assigned to clients as DCHP servers as well (incorrect).
Instead, the DNS servers should be 192.168.1.1 and 2601:645:400:80:26a0:74ff:fe74:caf1: that is, the DNS server needs to assign clients iits global address, not the link-local address.
This is not a unique issue for this Orbi model; I suspect this is the culprit of several other issues on this board as well. For a bit of a deep dive, see:
https://blog.zivaro.com/need-know-link-local-ipv6-addresses
https://en.wikipedia.org/wiki/Link-local_address#IPv6
https://tools.ietf.org/html/rfc4443
http://gtri.wpengine.com/frequently-asked-questions-ipv6https://forum.vyos.io/t/dns-requests-coming-from-ipv6-link-local-instead-of-global-ipv6-address/2238
And related issues on the forum like,
https://community.netgear.com/t5/Orbi/RBR50-no-IPv6-after-V2-5-1-8-update/m-p/1865729#M82970
Here's hoping for a fix.Thanks, Geoff
