manuel-c23
May 13, 2018Star
[Bug] Wired backhaul + Router reboot = KO
I use a wired backhaul connection
The router gets rebooted (e.g. auto firmware update, settings change, blackout, manual reboot)
Backhaul connection goes KO, the system don't recover the wired ...
May 14, 2018Guru - Experienced User
Heavy segmented home? How so?
What Mfr and model Switches are you using? Any of them managed? If so, model#?
Did you set up 1 satellite first via wireless back haul, then connect the ethernet cable to the satellite from the router and let it reconfigure the system. Give it at least 5 minutes and watch for the top LED to turn BLUE if successful.
Does the satellite connect via wired back haul if directly connected to the back of the router with out anything in the middle?
franktribe wrote:
Same problem here. 2 satellites. Ethernet backhaul. Router rebooted. System was unresponsive for hours. Even tried slowly powering on each unit one by one waiting in between. Ended up having to go back to 5G backhaul then it recovered. 5G backhaul is more stable for me. I have daisy chain off.
budy
May 15, 2018Luminary
…so one thing I did notice over the last months is, that there are more people seem to have issues with the 5x-Orbis, than the 4x ones. This might be due to the fact, that the 5x are more widespread, but still…
- FURRYe38May 15, 2018Guru - Experienced User
Ya, my 40 series has been working solid since I got it back in Feb. No where near the issues seen like with the 50 series.
