SdeGat
Jan 30, 2022Apprentice
Buying a used satellite for my RBR50?
There are quite a few Orbi kits for sale on the used market but I have read that not all models have a dedicated backhaul like the RBS50. Is there a list of models that I could look up before buyin...
- Jan 30, 2022
The following models will work and have a backhaul.
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Keep in mind, only the 50 series devices having the wider 1733mbps backhaul. The others use the 866mbps backhaul.
Jan 30, 2022Guru - Experienced User
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
- SdeGatJan 30, 2022Apprentice
Thanks for the quick answer plemans :smileyhappy:
I don't see many 50s out there but the slower backhaul should be fine for most devices.
Are there any (other) performance considerations that I should keep in mind if I can choose between the models above? Higher the model number, the better?- plemansJan 30, 2022Guru - Experienced User
Its more about ethernet port availability on some models. The RBS40V has a built in speaker for alexa. The RBS50Y is an outdoor rated satellite.
plemans wrote:Its more about ethernet port availability on some models. The RBS40V has a built in speaker for alexa. The RBS50Y is an outdoor rated satellite.
Ah yes, ethernet ports would be nice as I could have a backhaul-connected-satellite in the basement and my devices connected to it by Ethernet. Some devices may not even have wifi for that matter.
plemans I just saw a used RBR50v2 kit. Would that force me to use the v2 as my router and connect my v1 satellite to it or can I just use the RBSv2 satellite with my current v1 RBR50?
They're interchangable. You can go eitherway. I'd just add the satellite to your current setup.
