dstranathan
Jun 03, 2018Apprentice
Buying additional RBS20 satellites for CBK40?
I rcenlty bought the new 2018 RBK40 mesh kit (which included 1 CBR40 modem/router combo and 1 RBS20 satellite).
Id like to eventually add an additional satellite.
Can I buy an additional...
Jun 03, 2018Guru - Experienced User
Yes, you can. I would suggest only using up to 3 satellites.
You find spec info here about each system.
https://www.netgear.com/orbi/systems.aspx
Scroll down to towards the bottom of the page for each model to see spec info.
Mostly the 50 series is (1733 + 866 + 400Mbps)
The 40 series is (866+866+400Mbps)
- dstranathanJun 03, 2018ApprenticeThanks. But where can I BUY the RBS20 individually?
