reuvenweiser
Dec 31, 2019Tutor
Buying advice - RBK23 vs RBK33 vs RBK50 vs RBK53
Hi! I'm looking into buying an Orbi system to help get better Wifi coverage in my house. The house is approximately 310 square meters (3300 square feet) spread over three floors, mostly concrete. Mod...
reuvenweiser
Dec 31, 2019Tutor
Thanks, plemans . As you were replying, I was updating my original post to describe the topology in a bit more detail. As I mention there, I do have ethernet from the third floor (where the modem/router is) to the first (inside a room with particularly thick, load-bearing walls). I think I once tried running to the second, but was unable to (the pipes for running cable weren't big enough).
Given that the walls are also concrete, is the most important consideration which floor the connections are on? Would I want to space the connections throughout each floor (e.g., one on the north side of Floor 1, one on the south side of Floor 2, etc.)? Or would the connections then be too far apart from each other?
Dec 31, 2019Guru - Experienced User
Ouch. Walls and floor are concrete. Thats not good for wifi. I'm sorry in advanced.
https://eyesaas.com/wifi-signal-loss/
Concrete is challenging and you've got in everywhere.
You're probably going to want to do a combination of things. And its going to take a lot of trial and error. I can't tell you the best layout because its literally going to be whatever you can make work. Benefit to using using something like orbi or another mesh network is keeping your same ssid with multiple AP's. And you're going to want to hardwire as many high bandwidth devices as possible.
Was the house wired with coax in each room? If so, moca adapters work well.
You can also utilize powerline devices.
Again, I can't tell you what'll work best. Utilize your ethernet drop and I'd take a stab at sneaking that 2nd line into the middle floor. The floors tend to be thicker concrete than walls (not always) so that will (can) help.
