LauraAMayer
Oct 23, 2020Aspirant
Buying Orbi
Should I buy the AX6000 or the RBK44 System? I am out in the country using an antenna for TV and a satellite for WiFi/Internet. I live in an old two-story 100+ year old farm house made with plaster and lathe with dry wall over it. So which one of the two would you suggest I buy?
1 Reply
Sort By
What is the size of the home? Sq Ft...
IF you have AX mode supporting wifi devices, then Orbi AX maybe an option. If not, then the Orbi AC system should work.
