Xsquid
Oct 14, 2019Aspirant
Bye Orbi
Had the rbr50 set with router and one satellite. Never did like it and it just went out. Had extended warranty and instead of getting orbi went with eero pro, 2nd gen, 3 pro units. Virtually nothing t...
Ken2122
Oct 16, 2019Tutor
In regard to the "system wide ad blocker". It appears that is currently in Beta stage. Have you found that your Eero device has been blocking all or a decent % off ads? My friend has set-up a Pi-hole on a Raspberry Pi device and reports about 94% of ads blocked. Having the ability to do this at the network level intrigues me. Would love to see this function on the Orbi.
Xsquid
Oct 16, 2019Aspirant
So far the ad blocker works really well. Ads are gone in apps and games. Have seen none, period. Just like having an ad free version.
I constantly change ad blockers as theu either miss adds or block website function. Macrumors I visit regularly. No ads missed at all, some miss one or two. Any pages you want me to try? So far I like it better than anything before.
Tried these and no ads
https://www.reddit.com/r/Adblock/comments/a1ao2j/some_sites_to_test_adblock/
none here
https://thepcspy.com/blockadblock/
It may have missed a few while browsing but I never noticed. If you know of someplace with a lot of ads I will test it. I like it though better than the app store blockers.....any of them.
