jpralle
Jul 07, 2020Aspirant
Bypass Account
I've had it with NetGear- minus Genie (end of life) the only management utility is the Orbi app on a mobile device. The bypass / parental controls functionality is bogus. You must loginto the bypa...
jpralle
Tried that- no dice. Additionally, only Circle available from Orbi app. And why don't the Orbi apps know what the device setting are? If I log in as administrator from an iPad, make a change, and then log in from a different device, those settings aren't propagated. Netgear is a joke.
Jul 07, 2020Guru - Experienced User
Sounds like you should contact NG support and have them help you out. Not sure what "No Dice" means.
The web page works for me and everyone else.
Also there are Circle and Orbi app forums for those apps that may have more information for you there.
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
