Psherrerd
Mar 04, 2021Aspirant
Bypass modem on cbk752 modem router
I currently need to use my cox cable modem. Is it possible to turn off the modem in the cbk752 modem/router Orbi mesh? If so what is procedure?
antinode
Mar 04, 2021Guru
> I currently need to use my cox cable modem. [...]
I'll just pretend that you have some good reason for that. And that
is a what, exactly? Maker? Model number? Simple modem, or
modem+router, or what?
> [...] Is it possible to turn off the modem in the cbk752 modem/router
> Orbi mesh? [...]
Does it have an Ethernet WAN/Internet port? If not, then there'd be
no place to connect an external modem in a useful way.
If what you really want from the CBK752 is better wireless-network
performance, and if your (unspecified) "my cox cable modem" were
actually a modem+router, then you might be able to configure the CBK752
modem+router as a wireless access point for use with your (unspecified)
"my cox cable modem". See, for example:
Psherrerd
Mar 05, 2021Aspirant
As for the reason, my wife wants to keep our landline. The cbk 752 modem will not allow that. This model wan on super sale open box and I had anticipated that I could simply bypass the modem. It doesn't seem that I can.
