Psherrerd
Mar 04, 2021Aspirant
Bypass modem on cbk752 modem router
I currently need to use my cox cable modem. Is it possible to turn off the modem in the cbk752 modem/router Orbi mesh? If so what is procedure?
michaelkenward
Mar 05, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi with Built-in Cable Modem - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Psherrerd
Mar 05, 2021Aspirant
thanks
