Psherrerd
Mar 04, 2021Aspirant
Bypass modem on cbk752 modem router
I currently need to use my cox cable modem. Is it possible to turn off the modem in the cbk752 modem/router Orbi mesh? If so what is procedure?
Psherrerd
Mar 05, 2021Aspirant
As for the reason, my wife wants to keep our landline. The cbk 752 modem will not allow that. This model wan on super sale open box and I had anticipated that I could simply bypass the modem. It doesn't seem that I can.
antinode
Mar 05, 2021Guru
> [...] I had anticipated that I could simply bypass the modem. It
Right. But you might not need to. See "If what you really want
[...]", above. As suggested earlier, a more detailed description than
"my cox cable modem" would make specific, useful advice easier.
