Zolyo's avatar
Zolyo
Tutor
Feb 28, 2021
Cable connection to Orbi satellite
Hi Netgear community
I want to ask for help...
I live in a townhouse and got a granny flat at the back of the house which has been rented out.
We use Orbi RBR 50  + 1 satellite.
We never had a issue with connection. It covers whole 280sqm house + granny flat.
But I need some help with a problem that our tenant raised...
So the tenant was told by her work that she needs to have wired internet for her to work, not a wifi.
(do not know... the new boss thinks that wired network is more stable)
Due to the cost issue, we did not install a separate modem point in our granny flat.
(we are paying internet for the granny flat and our house, NBN 50Mbps)
My question is...
1. If we buy an extra satellite for our tenant and if she uses wired connection to the satellite, then would it consider a wired internet???
2. If above cannot work, then what would be best solution for a granny flat tenant to have a wired internet???
  • You might contact a local computer shop and ask for recommendations to have someone help you wire connect the two buildings. Would be too much for someone to help you with this. No activation is needed. Just connect one end of the wire to the RBR and one to a RBS at the flat or you can connect a Ethernet LAN switch at the granny flat, like a NG GS-108 swtich so the tennent can connect more then just one wired device if needed. This would be a full wired connection for there needs.
  • FURRYe38's avatar
    My question is...
    1. If we buy an extra satellite for our tenant and if she uses wired connection to the satellite, then would it consider a wired internet???  No.
    What is the distance between the main house and this "granny flat"?
    One can connect a wired CAT6A cable between the main house and this remote location if the distance isn't too far.
    • Zolyo's avatar
      Zolyo
      Tutor
      it is only 5 meters!
      And i do think they(granny flat) has an ethernet socket built into the wall.
      I do not know how to activate it!
      • FURRYe38's avatar
    • Zolyo's avatar
      Zolyo
      Tutor
      the town house was sold with grnny flat....
      Very tiny....
