Zolyo
Feb 28, 2021Tutor
Cable connection to Orbi satellite
Hi Netgear community I want to ask for help... I live in a townhouse and got a granny flat at the back of the house which has been rented out. We use Orbi RBR 50 + 1 satellite. We never had...
- Feb 28, 2021
You might contact a local computer shop and ask for recommendations to have someone help you wire connect the two buildings. Would be too much for someone to help you with this. No activation is needed. Just connect one end of the wire to the RBR and one to a RBS at the flat or you can connect a Ethernet LAN switch at the granny flat, like a NG GS-108 swtich so the tennent can connect more then just one wired device if needed. This would be a full wired connection for there needs.
Feb 28, 2021Guru - Experienced User
Zolyo
Feb 28, 2021Tutor
FURRYe38 wrote:You might contact a local computer shop and ask for recommendations to have someone help you wire connect the two buildings. Would be too much for someone to help you with this. No activation is needed. Just connect one end of the wire to the RBR and one to a RBS at the flat or you can connect a Ethernet LAN switch at the granny flat, like a NG GS-108 swtich so the tennent can connect more then just one wired device if needed. This would be a full wired connection for there needs.
awesome Furry!! i got no idea what they mean but I will try to remember them before talking to some local computer shop guy.
Thank you very much!
I think connecting a Ethernet LAN switch to granny flat seems a likely option at this stage! And also thank you for switch recommendation!
