Retired_Member
Aug 21, 2024Cabling new access point to ORBI RBR50
hello I have a device which I cannot force to join my orbi satellite. The device is a fixed device and will not move from its current location. I have a CAT6 port 10m away from the device whi...
CrimpOn
Aug 21, 2024Guru - Experienced User
Yes, this is a perfect situation to deploy an inexpensive WiFi access point. There is no need to hide the WiFi SSID, but you certainly can hide it if the device allows you to key in the SSID instead of choose from a list of visible access points. Probably best to create this new WiFi network on a channel far from the existing network (to reduce interference).
