AMWLADY
Aug 06, 2020Follower
Calling all Netgear Orbi Mesh geniuses: I NEED YOUR HELP
Bear with me, friends.. I purchased an ORBI ROUTER/MODEM with modem and 3 satelites. We are old folks. In our 60s, but we still work and during the pandemic needed towork from home. I also teach ...
Aug 07, 2020Guru - Experienced User
What was the problem with the Orbi CBK system. What were you seeing problems with?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
