Reddog1954's avatar
Reddog1954
Follower
Mar 04, 2019
Camera Connecting problems - Only one satellite will work
1 - D -Link Cams will not connect
2 - will work with only one satelitte.  When the 2nd is connected system goes down
Windows 10
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the model# of the Cameras?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO.
    Windows 10
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Reddog1954
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
