icermize
Dec 12, 2019Tutor
Camera doesn't connect to satellite, other devices do. Orbi RBK22
I have the Orbi router in the rear of my home and the satellite in the front. The satellite is hard wired to one of my computers and my tablet is using the satellite WiFi.. I placed the satellite i...
Dec 12, 2019Guru - Experienced User
What firmware are you on?
Have you tried rebooting the orbi setup? I know it sounds stupid but it does sometimes cause a re-association.
Have you tried enable/disable: mu-mimo, beamforming?
How far from the router is the satellite? 30ft minimum is recommended or orbi struggles with the association from router-satellite.
- icermizeDec 12, 2019Tutor
Thank you for your response. The router and satellite are about 25 ft. apart. However, the satellite is only about 5 ft. from the camera (satellite upstairs, & the camera just below downstairs).
Firmware V2.3.5.26
I've rebooted several times. Occasionally rebooting causes my camera to appear on a different port than it started with. This forces me to change the setup on my camera app so that I can access it which is why I want to be able to assign a port to the satellite in the first place.
I have no idea what Mu-mimo or beamforming are but I do see the option to enable them. At the moment, I can't reboot the system so that will have to wait.
- CrimpOnDec 12, 2019Guru - Experienced User
icermize wrote:I've rebooted several times. Occasionally rebooting causes my camera to appear on a different port than it started with. This forces me to change the setup on my camera app so that I can access it which is why I want to be able to assign a port to the satellite in the first place.
Assigning an IP address to a device is done on the Orbi web interface, Advanced Tab, Setup, LAN Setup. Click on "Add" at the bottom of the table. Fill in a name you want the device to appear as, the WiFi MAC address of the device, and the IP address you want it to have. (To avoid extra steps, I would assign it the IP address it has right now.)
The "rebooting" part is for the camera, not the Orbi. This is a frustrating part of modern "mesh" WiFi systems. When a device is turned on, it looks for nearby WiFi networks, compares their signal strength, and then connects to one. Devices which are designed to "roam", such as phones, tablets, and laptops, are programmed to search periodically to see if they would benefit by switching to a different WiFi access point. Devices that are designed to "remain in one place" are typically programmed to quit searching once they connect. When the Orbi boots up, the router comes up before the satellites, and devices often "see" the router first, connect to it, and "stick."
So, once the camera has an "assigned" IP address, tell the camera to reboot (or temporarily cut off the power). When it comes back up, it may connect to the satellite.
I appreciate your explaination and advice but am still confused about forcing the camera to connect to the satellite. I don't see any option for that to happen. Icer
