icermize
Dec 12, 2019Tutor
Camera doesn't connect to satellite, other devices do. Orbi RBK22
I have the Orbi router in the rear of my home and the satellite in the front. The satellite is hard wired to one of my computers and my tablet is using the satellite WiFi.. I placed the satellite i...
SW_
Dec 12, 2019Prodigy
icermize wrote:...
How do I force my camera to select the satellite (or force the satellite to select the camera) ?
If you're comfortable with telnet cmd, turn on Orbi Guest Network (tick allow client to see each other on Guest Network) with a new SSID, then set a different Guest SSID for each/target Satellite via telnet cmd. Then you can force each camera to connect to each/target Router/Satellite with the respective SSID. Check out this How to enable separate SSID on Guest Network.
Good luck!
icermize
Dec 12, 2019Tutor
Thank you for the tip. I'll take a look at the process later on. Icer
