rp17
Nov 20, 2019Guide
Cameras and other devices not connecting to satellites
I see this issue has been raised and there doesn't seem to be an answer. I have ring cameras all around my house and I have an Orbi base station and 3 satellites. The cameras all have poor signal a...
CrimpOn
Nov 20, 2019Guru - Experienced User
Have you tried using the Ring App to "Change the WiFi Network" and then have it select the Orbi (again) from the list of available networks?
Or, do a "reset" on the Ring and set it up again?
This issue of devices connecting to an Access Point that even the dumbest human knows is inappropriate remains one of the top mysteries. Solving it would improve the Orbi experience immensely.
- rp17Nov 20, 2019GuideI have done both multiple times as well as change a ton of settings within the orbi GUI and nothing helps. Thanks though.
- CrimpOnNov 20, 2019Guru - Experienced User
How about this: go to the Orbin web interface, Advanced Tab, Advanced Setup, Wireless Settings and turn the 2.4G transmit power down to 25%. That will reduce the power output of all Orbi radios. THEN try to connect the Ring Doorbell to Orbi. Maybe the Ring thought the router WiFi signal was "poor, but good enough" and reducing power will make it prefer the satellite. The Attached Devices page will show if it changes to a satellite. Afterward, turn the power back up as far as you need to get good service throughout the house.
- rp17Nov 20, 2019GuideI did see this somewhere else on the community and change it to 25% but didn’t try rejoining them after I did it. I will try reconnecting them tomorrow and see what happens. Thanks again
