rp17
Nov 20, 2019Guide
Cameras and other devices not connecting to satellites
I see this issue has been raised and there doesn't seem to be an answer. I have ring cameras all around my house and I have an Orbi base station and 3 satellites. The cameras all have poor signal a...
chadarooskie
Mar 04, 2020Aspirant
Did you ever find a solution to this problem??? I am having the same issue. It will be connected to the Satellite (which is not 5 feet from the Ring spotlight cam) and have great signal.. then out of the blue it will connect itslef to the main Orbi Router and have harly no signal.
rp17
Mar 04, 2020Guide
I never fixed the issue. I tried everything suggested and still it jumps back and forth. I just deal with it because it seems to work ok the majority of the time
- FURRYe38Mar 04, 2020Guru - Experienced User
Did you try reducing the power out put on the RBR to see if this helps any?
rp17 wrote:
I never fixed the issue. I tried everything suggested and still it jumps back and forth. I just deal with it because it seems to work ok the majority of the time- rp17Mar 04, 2020GuideYes, I tried every percentage option and it didn’t help at all. In some cases it was worse
Possible a camera issue as well. It's up to the camera to connect to the wifi signal based on it's own ways of connecting and noise and signal quality. Maybe something the camera isn't handling well.
