rp17
Nov 20, 2019Guide
Cameras and other devices not connecting to satellites
I see this issue has been raised and there doesn't seem to be an answer. I have ring cameras all around my house and I have an Orbi base station and 3 satellites. The cameras all have poor signal a...
rp17
Mar 04, 2020Guide
I never fixed the issue. I tried everything suggested and still it jumps back and forth. I just deal with it because it seems to work ok the majority of the time
Mar 04, 2020Guru - Experienced User
Did you try reducing the power out put on the RBR to see if this helps any?
- rp17Mar 04, 2020GuideYes, I tried every percentage option and it didn’t help at all. In some cases it was worse
- FURRYe38Mar 04, 2020Guru - Experienced User
Possible a camera issue as well. It's up to the camera to connect to the wifi signal based on it's own ways of connecting and noise and signal quality. Maybe something the camera isn't handling well.
rp17 wrote:
Yes, I tried every percentage option and it didn’t help at all. In some cases it was worse- rp17Mar 04, 2020GuideI have 3 cameras and a doorbell camera so it appears to just be a ring issue in general with Orbi. They don’t seem to play well together
