Rayman2
Nov 22, 2018Initiate
Can’t connect IP cam
I have two Fujikam IP cameras that won’t connect wirelessly to ORBI. I have read there is an issue getting devices to connect to 2.4 GHz but I can’t see where to turn off the 5 GHz radio. Any help is ...
- Nov 27, 2018
The issue was resolved by changing the network in the Fujikam Vimtag software on iPhone. The app stored the old network setting for the prvious ASUS router. No issue with ORBI settings. No need to turn off any radios.
Nov 27, 2018Guru - Experienced User
Can turn down the 5Ghz radio power by going to Advanced Tab/Advanced Settings/Wireless.
- Rayman2Nov 27, 2018Initiate
- FURRYe38Nov 27, 2018Guru - Experienced User
Ah glad you figured it out. Might not have guessed that one. :smileytongue: Mark this post as solved so others will know if needed.
Enjoy. :smileywink:
