LLJ
May 03, 2022Star
Can’t connect iPhone 13 pro to cbr40
I have a cbr40 and my iPhone won’t connect to it. Internet and Wi-Fi are working but I can’t get into the app to do anything. Tech is not a strength for me so maybe I’m missing something very simple. ...
Jul 18, 2022Guru - Experienced User
Any progress on this?
LLJ wrote:
I have a cbr40 and my iPhone won’t connect to it. Internet and Wi-Fi are working but I can’t get into the app to do anything. Tech is not a strength for me so maybe I’m missing something very simple. I’ve pushed the reset button, I’ve unplugged the unit from power then plugged it back in after several minutes. My only thought is to delete the app, download it again then see if I can get into it. I’ve read there are some issues with this so I’m hesitant to pull the trigger on this. Can anyone help me fix this. Many thanks…
