FaithBWell
May 01, 2021Aspirant
Can’t connect my phone to 2.4 network for FEIT Smartbulb setup
I just set up my new Orbi 6 mesh WiFi today. I am in the process of reconfiguring everything--but the FEIT smartbulbs require the device you're using to connect them to also connect to the 2.4 netwo...
CrimpOn
May 02, 2021Guru - Experienced User
Amazon is bringing me a FEIT Smartbulb tomorrow. Will be interested to see how it goes.
FaithBWell
May 02, 2021Aspirant
I got it solved. what a pain, though.
I went through the connection, it failed; and then there was at one point a "Switch pairing mode" that was available. I got the lights to a slow blink; then there was an option to go back to network settings on the phone and connect to ...something related to the bulbs... Like it's own network? ?? and they went right in after that. I *wish* I had gotten all the screen shots on the phone...
I then pulled out two newer bulbs, and those connect way faster with less issues. I bet the ones that amazon will bring you go right in. the ones I was trying to reconnect were a few years old--which I hadn't thought about in the beginning.
If anyone does come back with issues, though--I'm writing this here--because I'll try to help. that was several hours of my life I can't get back, and if I can save anyone else that aggravation... hahah
- CrimpOnMay 03, 2021Guru - Experienced User
FaithBWell wrote:I bet the ones that amazon will bring you go right in. the ones I was trying to reconnect were a few years old--which I hadn't thought about in the beginning.
Correct. The blinking light is a bit annoying since it is on FULL BRIGHTNESS. My phone was connected at 5G and the bulb connected to Orbi WiFi right away. The one thing I found a bit unusual is that the Feit app reports the bulb's IP address as my public IP address, rather than the IP address the bulb got from the DHCP pool. Seems like the programmers goofed there. Another odd thing is that the WiFi name is set to match the WiFi SSID that the phone is connected to, rather than being an input field. I thought it would be a fun test to set up a bulb while the phone was connected to the Guest network, but have the bulb connect to the Orbi primary network. With the SSID not being an input field, that option is not possible.
I still find the Feit app awkward. For example, it is possible to set "effects", but there is no button for "no effects." There's a color wheel, but no place on that screen to select white. Another example, it is not at all obvious how a person edits a bulb (perhaps to assign it a name). Turns out it is one of those "long press" things.
Was a fun experiment.
- FaithBWellMay 03, 2021Aspirant
Finding the FEIT App "awkward" is the understatement of the year, lol
It actually works better on android than on apple platforms.
And unfortunately, after the experiment I had yesterday--with the older bulbs and the newer bulbs, there is going to be no one-size-fits-all answer to this dilemma. Costco is selling those dam bulbs, and they last a LONG time. I think the keywords are going to be something about the slow blink and alternative setup. In the future I will likely seek different bulbs--but all the feit bulbs I got at costco when they had a big coupon for them.
I sincerely appreciate your time and efforts. You were light years more knowledgeable than the support person I got on the phone--who was reading from a script, didn't think, and basically said, "bye".
