Agugil
May 18, 2020Follower
Can’t connect router to my WiFi (ATT)
I successfully connected my Orbi along with two satellites to my router (ATT U verse); this morning I am having trouble connecting ; I have gone through set up multiple times unsuccessfully ; the message I receive is No internet connection available; . It shows me being offline with the internet but green lights for my two satellites..how do I achieve 3 green lights including my router?
1 Reply
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
