julescurty
Jul 18, 2022Aspirant
Can’t connect to Orbi LBR20
When I first set the router up we had IPads, smart tv and phones connected to the Orbi router now we can’t get any device to connect to it. The signal available is not the strongest but it pulled it v...
CrimpOn
Jul 18, 2022Guru - Experienced User
Do you have a device that can connect to the router with an Ethernet cable?
(desktop? laptop? TV? )
CrimpOn
There is a difference between 'reset' and 'factory reset'.
- Reset causes the router to reboot, but does not change any configuration settings
- Factory reset erases all user configuration, which includes changing the WiFi SSID/password back to what is printed on the product label.
