Kellybwoods
Aug 05, 2020Aspirant
Can’t detect network when setting up orbi
This isn’t a new Orbi. I’ve had it for about a year. WiFi stoped two nights ago. Called internet provider. All fine on that end. Thought it was the modem. Got new modem but the problem continues. I ca...
Kellybwoods
Oh wow. Okay. It was so easy to set up. I don’t understand why it’s so difficult now. I did that reset yesterday. Will try again and try to find cable to connect a computer. We’re MAC. Will that still work?
Aug 05, 2020Guru - Experienced User
Of course, I use Mac as well. Long time Mac user. Some macs don't have ethernet ports. This is fixed by getting a inexpensive USB to ethernet adapter in case.
- KellybwoodsAug 05, 2020AspirantOkay. Yes, no port was my concern on the Mac. 👍🏽
- FURRYe38Aug 05, 2020Guru - Experienced User
:smileywink:
- MstrbigAug 05, 2020Master
I know this is probably a dumb question, but did you do a fresh install and setup, using the app, after the factory reset? And did you Unplug your modem (remove and replace the backup battery if it uses one) and Plug the modem back in, before setup procedure?
