donpearson
Mar 17, 2019Aspirant
Can’t get External IP Address for RBR40 in AP Mode
Orbi rbr40 can't get external ip in access mode due to being behind a proxy. All it’s showing is network ip. Anyway I can set it manually? This is a massive pain in the arse as I can’t login to Net...
- Mar 26, 2019I got a response from Netgear, got to simply forward the port 8080
michaelkenward
Mar 17, 2019Guru - Experienced User
donpearson wrote:
This is a massive pain in the arse as I can’t login to Netgear in the app.
Login to Netgear what?
Which app? Orbi?
As both FURRYe38 and dopey1620 explain, in AP mode there won't be an external IP address.
External IP Address for RBR50 in AP Mode - NETGEAR Communities
The way into an AP is usually through its local IP address, unless you are trying to use Remote Access.
donpearson
Since I put my Orbi behind a proxy I can’t use remote access but also I can’t login to Netgear in the Orbi app.
Clearly something is getting blocked somewhere but I’m unsure what.
- ekhalilMar 17, 2019MasterWhat error do you see when trying to connect to Orbi from the Orbi app?
- donpearsonMar 17, 2019AspirantThat app connects to Orbi fine.
It’s when I try and login to Netgear within the app I get an error wrong username or password all the time.- donpearsonMar 17, 2019AspirantThe wording is: an error has accrued please try again
