donpearson
Mar 17, 2019Aspirant
Can’t get External IP Address for RBR40 in AP Mode
Orbi rbr40 can't get external ip in access mode due to being behind a proxy. All it’s showing is network ip. Anyway I can set it manually? This is a massive pain in the arse as I can’t login to Net...
- Mar 26, 2019I got a response from Netgear, got to simply forward the port 8080
donpearson
Since I put my Orbi behind a proxy I can’t use remote access but also I can’t login to Netgear in the Orbi app.
Clearly something is getting blocked somewhere but I’m unsure what.
ekhalil
Mar 17, 2019Master
What error do you see when trying to connect to Orbi from the Orbi app?
- donpearsonMar 17, 2019AspirantThat app connects to Orbi fine.
It’s when I try and login to Netgear within the app I get an error wrong username or password all the time.- donpearsonMar 17, 2019AspirantThe wording is: an error has accrued please try again
- donpearsonMar 17, 2019AspirantThis may also help orbilogin.com also don’t work for me.
I’m guessing Orbi is unable to talk to Netgear due to my proxy so I need to forward the port Netgear use but I haven’t found that information yet
