Gellie
Jun 21, 2018Aspirant
Can’t get iPhone to connect
So if I’m approximately 50 ft from the satellite all good. @ approximately 75 -90 ft the iPhone won’t connect. It see the Orbi networks (strong signal) and just hangs or ask me for password, which it...
Jun 21, 2018Guru - Experienced User
Is MIMO, Daisy Chain and Fast Roaming disabled as well on the router?
Gellie
Jun 22, 2018Aspirant
Daisy Chain is Disabled.
the following is enabled:
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices | |
| Enable MU-MIMO | |
| Enable Fast Roaming |
- GellieJun 22, 2018Aspirant
Honestly it seems like my Iphone X will not connect to the satellite. I think when I'm ~50ft from my house it connects to main router, then when i move further away it drops from main router and doesent pick up the nearby satellite?
