Gellie
Jun 21, 2018Aspirant
Can’t get iPhone to connect
So if I’m approximately 50 ft from the satellite all good. @ approximately 75 -90 ft the iPhone won’t connect. It see the Orbi networks (strong signal) and just hangs or ask me for password, which it...
Jun 22, 2018Guru - Experienced User
You may need a out door satellite to help with range there. I've only seen single up to around 30-maybe 40 feet out side from inside single sources.
