UnleashedChaser
Jul 01, 2019Follower
Can 2 RBR-50 be used at the same time?
I have the RBR50 and 2x RBS50s, but my house is solid brick and my detached garage is about 100ft from the house. Wifi starts to dip a bit when I'm inside the garage working. I currently have a CAT6...
Fl1ntstone
Jul 01, 2019Apprentice
Hi,
It looks like using another RBS50 would be your best bet as the backhaul link would connect via the LAN Cable and it would belong to the same WiFi Network.
Good luck :)
