tdcarp
Aug 28, 2021Aspirant
Can a CBK40 modem/router be used only as a router; i.e. behind a separate modem.
Can a CBR40 be used as a router only? I'm having network problems and, although the CBR40 isn't all that old, I'm willing to replace it, along with a couple extenders that have worked well over the ...
Aug 28, 2021Guru - Experienced User
No. Only works as a gateway modem/router or in modem only or a faux wired AP mode operation. No router mode.
