Cheem
Aug 12, 2019Aspirant
Can a powerline adapter be used to connect an Orbi to my isp modem instead of a cat 6 rj45 cable
I want to locate my Orbi router in a room in the centre of my house so I can hardwire it with rj45 cables to my computer, Sonos and Hive heating hub located in that room (plus it’s the best place fo...
- Aug 13, 2019
Thanks to both of you for your help and recommendations. I now feel a lot better about my next course of action.
michaelkenward
Aug 13, 2019Guru - Experienced User
Cheem wrote:
As a cheaper alternative to a second Orbi satellite I’m considering purchase a Netgear PLP-1000 1 port 1 Gigabit powerline adapter as an alternative to the normal hardwire connection between isp modem and Orbi router. Is this a feasible way of connecting them and ...
Yes. I do this without problems.
You don't say what your modem is. If it is a modem/router then you may want to put the Orbi into wireless access point mode.
- CheemAug 13, 2019AspirantThanks for the information - much appreciated! I am using my isp’s modem/ router - a ‘plusnet hub one’ (sagem)
- michaelkenwardAug 13, 2019Guru - Experienced User
Cheem wrote:
I am using my isp’s modem/ router - a ‘plusnet hub one’ (sagem)Without a model number, that could be anything.
The model number is Sagem CS50001. If possible can you explain the difference/best option between using the Orbi in router versus access point mode with my described set up. I notice in AP mode that the ip adresses for all equipment is set by the modem (192.x.x.x) and router mode set by the Orbii (10.x.x.x) Thank you.
