Cheem
Aug 12, 2019Aspirant
Can a powerline adapter be used to connect an Orbi to my isp modem instead of a cat 6 rj45 cable
I want to locate my Orbi router in a room in the centre of my house so I can hardwire it with rj45 cables to my computer, Sonos and Hive heating hub located in that room (plus it’s the best place fo...
- Aug 13, 2019
Thanks to both of you for your help and recommendations. I now feel a lot better about my next course of action.
michaelkenward
Aug 13, 2019Guru - Experienced User
Cheem wrote:
As a cheaper alternative to a second Orbi satellite I’m considering purchase a Netgear PLP-1000 1 port 1 Gigabit powerline adapter as an alternative to the normal hardwire connection between isp modem and Orbi router. Is this a feasible way of connecting them and ...
Yes. I do this without problems.
You don't say what your modem is. If it is a modem/router then you may want to put the Orbi into wireless access point mode.
Cheem
Aug 13, 2019Aspirant
Thanks for the information - much appreciated! I am using my isp’s modem/ router - a ‘plusnet hub one’ (sagem)
- michaelkenwardAug 13, 2019Guru - Experienced User
Cheem wrote:
I am using my isp’s modem/ router - a ‘plusnet hub one’ (sagem)Without a model number, that could be anything.
- CheemAug 13, 2019Aspirant
The model number is Sagem CS50001. If possible can you explain the difference/best option between using the Orbi in router versus access point mode with my described set up. I notice in AP mode that the ip adresses for all equipment is set by the modem (192.x.x.x) and router mode set by the Orbii (10.x.x.x) Thank you.
- FURRYe38Aug 13, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
